CEL P0154
I had a CEL P0154 come on last week. I have cleared the code - but see that some folks believe it may be caised by a loose wire/connection. Can someone explain where specifically the connection is located? Thanks.
"Junction box" where the connectors are located are mounted just in front of the taillights, they are not in the brackets attached to the engine. Most likely under black plastic housings protecting several connectors.
I just got CEL code P0154 - Bank 2, sensor 1.
If I understand correctly, Bank 2 connectors are located under the plastic box on the passenger side?
The car is at 115,000 miles and I'm not sure when the sensors were last replaced - possibly 40,000 miles ago, if at all. Is it advisable to replace all the sensors, or only the one that triggered the CEL?
Thanks!
Thanks!
All I can add here is that on a carrera, Non Turbo there are Four.
Two pre-cat and 2 after the cat.
Two fronts control or have greater impact on Air Fuel Mix for my carrera
I think the Life Span is 60 - 100,000 Miles But are warrantied to 100,000.
No Comment on Turbo 02 sensors
Incidentally, to avoid wires scrunchinp up or clumping all together, Prior to install
Spin all wires till stretched out, kinks reduced, In the Opposite direction of when u Install.
Simply put - Just Un-wind the wires in Opposite direction of Tightening
This way they do not end up in a ball at end of sensor.
Also eliminates possibility of sending irregular signals to the DME
Interested to hear more on this subject
TJ
TJ
I replaced all 4 sensors with new one to solve the p0134 code since there was no record of them replaced on my car with 101Kmiles. Today, after 30 mins drive, I got P0154 (O2 Sensor Circuit No Activity), P119 (O2 Sensor Heater Cir Bank2) P115 (O2 Sensor Heater Cir Bank1) . I clear the CEL and they come back after 30 mins drive. Has anyone encountered this?
Hmmm. I used 15738s that cross referenced correctly. Also, I only replaced 2. Can't remember if upstream or downstream. Did yours come with connectors or the generic end that you can put the old connector on? From your description it sounds like it's not reading any input from them.
QN
