Need Wiring Diagram for HiFi
Does anyone have a wiring diagram for the hi-fi option stereo system in a '95? I'm going to replace my head unit, and since it appears that the connectors (asside from the CD changer and antenna) are not standard, I'll need to know which wires go where. I'm referring to those in the dash behind the head unit. (I will not be using the CD changer anymore.)
I was also contemplating replacing the amp under the passenger seat, in which case it would be helpful to know which wires go to which speakers. But if I do that, I should probably replace the speakers, too, which is more than I want to do right now. For now, it's just the head unit that will be replaced.
So, does anyone have a wiring diagram of the hi-fi stereo system?
Thanks!
Thanks!
This isn't exactly what you asked for, but maybe it's enough to get started. "GRMNXTC" posted it for me on Pelican a while ago and it was really helpful:
AMP Pinout:
Pin# Wirecolor Function
5 Brown Power GND
6 Brown Power GND
10 Red Power +12V
11 Red Power +12V
13 White/Red Speedo signal
7 Shielded Blue/Black Gnd for DSP controller
8 Shielded Blue/Red Data for DSP controller
9 Shielded Blue/Yellow Clock for DSP controller
16 Brown/Green Front Left Woofer -
17 Green Front Left Woofer +
24 Brown/White Front Left Mid/Tweeter -
25 White Front Left Mid/Tweeter +
19 Brown/Yellow Rear Left -
18 Yellow Rear Left +
20 Red Rear Right +
21 Brown/Red Rear Right -
23 Black Front Right Mid/Tweeter +
22 Brown/Black Front Right Mid/Tweeter -
15 Violet Front Right Woofer +
14 Brown/Violet Front Right Woofer -
AMP Pinout:
5 Brown Power GND
6 Brown Power GND
10 Red Power +12V
11 Red Power +12V
20 Red Rear Right +
![](https://forums.pelicanparts.com/uploads4/Head1099351314.jpg)
