VERTEX HID GROUP BUY OPEN 229.00 + shipping
Yes. They fit directly in to the projector housing. No mods needed. A direct fit. I have put 3 sets in about an hour to do for the first timer.
Mike
Mike
so I'm clear, once you change out for these headlights, the hi-beam toggle on the turn indicator is in-op? Are the HID's so powerful that they replace the need for hi-beams? I'm a little dubious on this mod, but the dark side is indeed strong....
Cows-4-Rent
HID Issues?
Hello All
I got in on the group buy for the HIDs and have been very happy with them. Just this weekend however, the left headlight clicks off after about 5 minutes of operation.
I have checked the connections and all is okay there. Has anyone else had the same problem? Ideas on cause or fix?
I am going to switch the balasts tonight to see if I can isolate to that.
Thanks....
Jeff
Thanks....
Jeff
I had to swap things around a few months ago for the same reason.
I had taken the "wedge the ballast into the fender well" approach, and one had dislodged itself, apparently after a spirited maneuver. I set everything back in place, and all was well again.
Hope the ballast swap takes care of it for you.
