Bent kinetic Control Bar
A few months ago, I had an offcourse trip outside of Turn 9 at WSIR.
I had the car taken to my mechanic and checked for damage as well as had them redo the alignment.
on the left side, the minimum negative camber that they could get to was around -3 degrees. This is usually close to the maximum and not the minimum. The right side was fine.
After looking around for a while, it seemed that the Kinetic control ARM, is bent around 20 degrees and obviously needs to be replaced.
While I wait for a new arm to be installed, I was wondering if anyone has ever had this piece replaced as well as recommendations on what else should the mechanic look for and do.
Thanks in advance.
Thanks in advance.
