993 Forum 1995-1998
Seat height
Old 06-08-2006, 03:25 PM
visible23
visible23's Avatar
Default Seat height
Is there any way to maximize head room in my 993? I am open to any and all possibilities. I have a sun-roof of course.
My car has what I believe are the standard seats, the driver's side has the powered adjustablity (awkward phrase but y'all get it I bet).
Thanks in advance.
Old 06-08-2006, 04:45 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Have an upholstery shop remove some seat padding. Put some spacers under the front allen bolts (find longer allen bolts) to tilt the seat back a bit. I had to to remove padding and do the tilt with my GT3 seats.
Old 06-29-2006, 06:45 PM
Felix
Rennlist Lifetime Member
Felix's Avatar
General consensus seems to be GT3 seats with BK (Brey Krause) brackets and Sparco sliders.
Old 06-29-2006, 10:30 PM
Garth S
Garth S's Avatar
Do these brackets and sliders offer some of the same benefit to the stock 993 seats? If so, where does one source them?
Old 06-30-2006, 02:33 AM
Felix
Felix's Avatar
No, that bracket/slider combo is for the GT3 seats. I'm not aware of anything you can do with stock seats to provided more headroom short of taking out some of the padding.
Old 06-30-2006, 02:49 AM
c993k
c993k's Avatar
You must like sitting very upright, I tilt mine back and it has lots of headroom, I have the hardback sport seats, Chris
Old 06-30-2006, 08:36 AM
Aussie Alan 993
Aussie Alan 993's Avatar
I had to put 1 inch spacer blocks to raise the seats to my prefered height. I am 5'8" and like sitting high.
You must be a giant if you have had the padding taken out of the seat and still find it too high.
Cheers
Old 06-30-2006, 08:41 AM
993inNC
993inNC's Avatar
Cheers
No I has to do with us TALL guys wearing a helmet in the car. At 6'3" I had to make up spacers and rails to get my GT3 seats raked back enough to fit me with a helmet. I also had to cut the seat side rails to acheive this.
Old 06-30-2006, 01:14 PM
trojanman
trojanman's Avatar
No one has mentioned reinstalling the seat in the rear-most rail holes (a very simple DIY)... I did this (I'm 6'6"), and am much more comfortable with both leg- and head-room.
Old 06-30-2006, 10:38 PM
visible23
visible23's Avatar
Ah! Now that is more like it. Jeff...is it a simple DIY even for someone who is fairly inept at wrenching? Is the car sent from the factory with the seat in the _______rail-holes (please fill in the blank)?
Thanks in advance for the info.
Old 07-01-2006, 05:04 AM
Caveman
Caveman's Avatar
All those ricers with their dope, laid-back drivers don't seem to have any problems....
Old 07-01-2006, 05:43 PM
fbfisher
fbfisher's Avatar
Factory in the front holes, there is a second set that gets you about another inch. All you need is the correct alan wrench size 6mm. Key is slow steady force applied so as not to strip the heads. There is a slidy thing in the rails that the bolt threads into. Just slide it back to the second set, screw them back in and you're done. Very quick and easy as long as you don't strip the bolt. I'll search for the thread DIY thread on this that I used and post if I can find it.
Old 07-01-2006, 05:47 PM
fbfisher
fbfisher's Avatar
Here is one, thanks to Viper Bob:
https://rennlist.com/forums/showthre...ght=seat+holes
Old 07-19-2006, 01:08 AM
shattergard
shattergard's Avatar
Question I am Only 5`8. Can my driver seat height be raised?
Hi Everyone,
I am only 5`8 and really would like to sit a bit higher-up then my power seat allows. Is there a simple way of raising my seat one or two inches.?
As always thanks everyone
Jordan
Old 07-19-2006, 08:54 AM
Bull
Bull's Avatar
The rear most mounting holes will get you about an inch of additional headroom and seat travel. However, if wearing a helmet is the issue, you will likely need to do more than this simple fix. I went to after market seats bolted directly to the floor, which gives me about 1/4 inch of clearance with my helmet on.
Quick Reply: Seat height
