993 Forum 1995-1998
Ballast Resistors Redux
Old Jun 7, 2006 | 06:24 PM
BobbyT's Avatar
BobbyT
Default Ballast Resistors Redux
I'm still trying to get a grip on what these things do, so please bear with me. As I understand it, in layman's terms, the engine bay blower is powered via a two-stage relay. One stage of the relay sends power directly to the blower motor for the high speed. A separate relay stage sends power via a different circuit through the ballast resistor, which uses some of the power to generate heat, and the reduced power goes to the blower to run it at low speed.
Same idea for the AC condenser and oil cooler blowers. Is this correct?
Old Jun 7, 2006 | 08:40 PM
User 4221's Avatar
User 4221
You are correct on the theory of operation. Also correct on the AC and Oil blowers. I can't speak to the engine bay blower.
Old Jun 7, 2006 | 08:50 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Correct, & it's the heat that fries the resistor. The newer design part has a washer fitted as a heat sink.
