Info on S Models?
Noodle Jr.
Info on S Models?
Where can I find detailed info on the 96 through 98 S models? Performance, weight, numbers, etc. Was there a widebody option for those years or where they just the S models?
Still plays with cars.
96 -97 98 C4S widebody, turbo suspension and brakes 18 inch wheels std. C2S came out in 97 - wide body but standard suspension and brakes 18 inchers std. All engines the same as I recall.
Originally Posted by mborkow
i didn't think the c2s came standard with 18" wheels...
Originally Posted by Terry Adams
Correct. The 18" Hollow Spoke Technology wheels were about $1500 option.
______________________________
'97 Carrera S 100% original
Originally Posted by Cactus
How much additional weight did the awd add on the 4? How much did it affect performance vs. the 2S?
Carrera S has a 4.91 kg/hp ratio which gets us to 1400 kg DIN weight. (verified in the brochure,
Carrera 4S has a 5.08 kg/hp ratio so the weight is 1448 kg Din.
Still as per porsche christopherous,
Carrera S
80 to 150 kilometers/hour are done in 6.176 seconds
100 to 200 Kph are done in 12.486 sec.
Carrera 4S
80 to 150 kph are done in 7.709 seconds
100 to 200 kph are done in 15.721 seconds
regards
Originally Posted by SCMomentum
I don't believe that the 4S came with the turbo suspension, just the brakes. I think the M030 was an option, however.
the 4S as per PET catalog came with either the regular, M030 or M033 suspensions depending on the country of sale.
The 4S and Turbo have exact disc brakes, calipers, but different brake fluid reservoirs, the 4S having the regular carrera one.
In Europe- The 4S came with either M030 or M033 struts.
In USA - The 4S came with either M030 or regular coupe struts
In Europe - The 4S came with a unique 20mm front stabiliser bar and silent blocks (21mm for normal and 22mm for M030 & turbo)
USA - The 4S came with 20mm front bar as the regular carrera (22mm for M030 and turbo)
In Europe - The 4S came with an 18mm stabiliser rear bar and silent blocks (20mm for Carrera S and M030, 21mm for Turbo)
In USA - The 4S, M030 and the 2S have an 18mm rear stabiliser bar, 19mm for turbo.
The 4S came with front springs either marked blue M033 or orange green M030
USA front springs are orange
Europe- The 4S came with unique rear springs marked Pink
USA- The 4S came with gold coloured yellow rear springs, or light blue for M030
I hope I did not miss anything
