Interior Pic thread
Originally Posted by cabrio993
The TIP buttons on the steering wheel are to adjust volume and skip songs/stations on radio.
Originally Posted by David in LA
Chuck - Do you have info on this mod or did you have a shop do it? I have a three spoke tip wheel and TrafficPro that needs to installed one day...Thanks
I'm not Chuck but he does have a Cab like mine..so you were only half wrong
DIY for the 3 spoke radio controls is of course at:
http://p-car.com/diy/steeringradio/
The key to it is the special Tip ring between the steering wheel and the column and the tip wiring harness. The rest is just wiring stuff.
Originally Posted by Novice
ah... I am still polishing the tach rings, in the mean time, here is a pic I posted after the pedal group buy
Originally Posted by jmayzurk
Mine:
Originally Posted by LJ in Van
Is that the factory CF trim or is that aftermarket? If aftermarket, where did you get it?
Door handles and Shift **** are factory
They are after market installed from the P.O. So I have no idea.
I believe mine is the same set that automotion sells. Color and texture is identical to factory.
Please note that the factory piece for the speedo, tach ...etc is a one shaped piece not glued on like mine.
LJ in Van,
There is a really nice factory type cf guage surround on the FVD site that not only goes around the guages but under as well. It's $355 though. They also have the complete kits.
If I had been home today I would have received my CF OEM parts from Germany.
Obtained at a significant savings.
I'll post a report after I get them (hopefully Monday)
Hi Guys,
I went to a local upholstery workshop to get my interior done & to my surprise they did a very good job on my car. Look at the stitching on the door handle, they say this is the hardest part of the whole interior & require fine precise workmanship.
I'll pose more pic soon.
