Volk Racing TE37 Wheels
Originally Posted by Harvey Yancey
8...
Weight:
17lbs Front
18lbs Rear
Weight:
17lbs Front
18lbs Rear
sold my BBS -RS IIs and looking for a second wheel set. Anyone else running these TE37s? My car is slammed pretty low and I'm a bit concerned about the offsets. 5 mm out may make it tough to fit my current tire set up (MPSC 235 fr and 285 rears). What tires are you guys running on these wheels?
I have a set and run RS ride height/alignment with zero issues. These things are freakishly light, when I take them off and put them on my tire storage rack, I brace myself for the weight of "regular" wheels but it never comes. They are made beautifully too.
Chris,
I'm amazed that you were able to squeeze 11" wheels in the back. However, from you're pick it is clear that your ride height must be at least 2" higher than mine. I can't even squeeze my pinky between the tire and the fender lip on the rears with my 285 MPSCs on BBS RS GT 18x10 ET65.
Jimmy,
What sideskirt is that on your car?
Jimmy,
