Hydraulic clutch adjustment method....
Lifetime Member
Lifetime Member
This was posted on the 996 board, have you guys hear of this method of hyarulis clutch engagement adjustment?
https://rennlist.com/forums/996-forum/179383-excessive-clutch-travel.html
Lifetime Member
Lifetime Member
that's the first thought that came in my mind. air is highly compressable, so it would be very difficult to ensure that the clutch is 100% disengaged with this method....
I've never heard of this before, but I wish there was a way of lowering the point where my clutch pedal engages. Could you shorten the piston arm on the slave cylinder?
Addicted Specialist
So when I was 16 or so, my friend and I (gearheads from birth ) had an acquaintance with a moped that had a squealing rear brake. It was baaddd, as in you could hear him coming from 1/4mile away. So we (in jest!) tell him that a bit of WD-40 would cure that sqeal ...works in door hinges. ...He did it
Keep these folks away from anything I drive.
Edward
Edward
4th Gear
I find this quite worrying. If the point at which the clutch bites is causing that much concern look for a mechanical method to cure it. Don't introduce something that the system is designed to keep out.
Seared
Clutch? Who needs it? Waste of time.
Just learn to rev-match and slip the tranny into the next gear without it.
My father taught me this when I was 13...... worked like a charm on my worn-out '66 VW.
Andreas
Andreas
