Fog Light Lense-can you just replace it?
My drivers side fog light has a hole in it, from a rock I assume. Can you just replace the lense or do you need to replace the whole assembly?
Unless there is some DIY method to replace the lens, you will only be able to buy the assembly. After replacing two fog lights in three years, I put the heavy 40mil clear lens covers on them and the headlights, which I purchased pre-cut from www.mats.com. Four years later, with 100+ track days, I have not had another one break.
Bob is right--they only come as assemblies. You might perhaps be able to find lens that are okay on broken housings from a dismantler, which you could then use to piece on to your housing. But, it probably isn't worth the search. I'd just buy the new light (or two, if the other one is "weathered") and protect them with the film.
They only come as 'full assemblies".
I replaced my front right (flying rock make a hole in it!) using EBAY !!!
You _should_ be able to pick up one, on Ebay, for around $50. Much better than the $220'ish that the $tealership will charge for ONE!
G.
G.
