Does anyone know the the spring rate for the standard US M032 springs (non-sport)? I have found just about all other spring rates but the M032. Thanks.
Here is what I found so far:
US factory M030 150-200 fr 225-275 rr
Eibach 7209 120 fr 200 rr
Weltmeister 180 fr 268 rr
H&R peformance 240-260 fr 280-310 rr
H&R coilovers 290-310 fr 350-370 rr
H&R supercup 310-350 fr 385-435 rr
BIlstein PSS-9 225-250 fr 400-685 rr
"Motorsport" 600 fr 800 rr
M032 - ???
M029 - ???
M032 - ???
M029 - ???
Martin S.
close
- Join DateMay 2001
- LocationSolana Beach, CA
Liked:557 Times in 363 Posts
Finally a question I can answer!
Front: 143 Lbs Rear: 297 Lbs.
This M033 data above is from Gert Carnewal's web site Gert Carnewal web site
These M033 spring rates are within a few pounds from stock...looking at stock at about 150 front and 300 rear. This could be a sweet set up with the right shocks, perhaps Bilstein HD? This is the comfortable ride option with the effect of lowering, not a sporting ride.
Also note the ftont ride height can be fine tuned slightly with some minimal threading on the shock body.
The car's rear ride height can be fine tuned by using one (1) of three (3) shims, 3mm, 5.5mm and 8.0mm.
