What's a good tire pressure for Sport Cup's
On Monday I'm running my first DE with R compound tires - Michelin Sport Cups. For those of you with experience with these tires on a 993, what inflation pressures have you found to work best? Dry track? Wet track?
I start out at much lower cold temps, about 26 front/27 rear. You want to be around 32 to 36 psi for hot pressures, about 180-220 degree tread temps. They need to be pushed really, really hard to get up to proper temps.
Check out this thread that Chris Cervelli started: https://rennlist.com/forums/showthre...c+pressure+hot
I don't run the MPSC in the wet for the reasons mentioned by Bob.
