oil change question
Originally Posted by Arrwin
I have a '96 so I don't think it should be too different. Do you use a filter wrench on the small filter? If so, how do you finnagle it in there?
Originally Posted by Van1
The first time I changed my oil, I used a metal band type filter wrench that uses a 1/2 in drive ratchet in the center. Fit with no problem. I can't quite get my Hazet cap type wrench in there although it would fit if I were to grind about a 1/4 - 1/2 inch off of it. I just changed my oil this weekend for the second time and I was able to get the filter off using just my hand.
Hmm, but I don't think I'd want my filter so loose that I could remove it by hand. I couldn't get my cap-type filter wrench onto the little filter. That's why I gave up on that idea and just removed the oil line.
I removed the oil return line for the first time during my last oil change. I know almost 2 whole qts. came out of there. I was stunned. I've done plenty of 993 oil changes and always wondered why I never got much more than 9 qts. out of there. Now I know. I've never had a problem getting the small filter out with the hard line in place. I use the shrinking grabber tool that goes on a 3/8" extension and I remove the rubber heat exchanger tube.
Lifetime Member
Lifetime Member
Wow! Two quarts is a lot!
I think the best tool to use is the oil filter cap, it is the same size for both 993 and 996. I got my cap at Pep boys, they have a variety of sizes so it is best if you bring your filter there to try it on.
For the large filter I hand tighten only (make sure hand is not greasy), on the small filter I use the oil filter socket and ratchet to give it another 1/2 turn once it is tighten by hand as there isn't enough space to get your hand up there to put good torque on it.
![](http://forums.rennlist.com/upload/oilfiltercap.jpg)
Once I have the orange hose/ducting removed, I seem to have more than ample clearance to work the small filter with my hands. The only thing the oil line prevents me from doing is getting a cap style wrench on due to its height (about and 1" to 1 1/4 " tall). If my cap wrench were more like 3/4" tall, it would slide between the line and the filter easily.
...If my cap wrench were more like 3/4" tall, it would slide between the line and the filter easily.
Lifetime Member
Lifetime Member
I know what crush washers are, the ones used on our 993 is a flat aluminum disc and there is no way you would be putting that much torque on them to crush them. If you are you are most likely over torquing them.
Ah ok...maybe the trick is to tighten just enough to it can be removed by hand, b/c I don't see any way of getting a wrench past the oil return tube.
