DACH Catless X-Pipes: Stalling
hey guys, so I have had my DACH Catless X pipes for about 2 months now. They sound WICKED....BUT, once the car is warmed up, I'll pull up to a stop light, and the revs will dipp really low, the ECU will try to compensate by throwing some revs at it...and then it'll be fine. Most of the times though, the car will just dip too low and die. Is there a way to get aroudn this? Turn up the idle? If so, how do I do this!?! THANKS!
ADAM
(P.S. the DACH pipes only have 2 of the 4 O2 sensors hooked up.)
ADAM
ADAM
ADAM
ADAM
ADAM
Have a second set of bungs welded into the bypass pipes so that you can thread back in the secondary O2 sensors. If they are in the circuit (feedback to ECU) and properly grounded, you shoild have no CEL issues or mixture / idling problems. Just my experience.
Rennlist Lifetime Member
I'm going to speculate that it's not actually related to the bypass pipes unless the secondary O2 sensors are disconnected. I had bypass pipes on one of my 993s for over 2000 miles without an issue. I had the secondar sensors pulled up into the engine compartment and wire tied out of the way...no issues.
Here's my suggestions:
1. Make sure the secondar sensors are still connected to the wiring harness and tied up somewhere in the engine compartment (not below).
2. Make sure your ISV is cleaned up.
3. I'd disconnect the battery for a reasonable time and then reconnect...start the car. This will reset everyththing to base code and may help.
4. Check for MAFS/throttle body adaptation (I can't explain this well at all but you can encounter issues if the gas pedal is pressed at all while the battery is disconnected - I'd PM/email Steve Weiner for details & process to resolve).
Cheers,
Rick
Cheers,
Rick
Originally Posted by viperbob
I'm with Dannen.
Cheers,
Rick
Cheers,
Rick
What he needs to do is wire tie them to anything in the engine compartment that provides a ground (heater box above the bypass does just fine). What I bet he did was dosconnect the battery and the first time he took it out the car stalled. Should have worked itself out with in 20 miles.
Chris, you MUST be kidding me! I NEVER blamed the product! I said my car was dying since I got them, not blaming hte product, I'm sure this happens with ALL catless pipes. Geesh. ANYHOW, the secondary o2's are plugged in and hanging ziptied in the engine compartment. WHat is the ISV? How does one clean it!?! Any info is great! Chris, I DO NOT blame the pipes, I know it is a catless issue, not a DACH issue!
ADAM
ADAM
As for the whole 20 miles workout....this is NOT the case man. The car runs fine UNTIL it is warmed up...THEN dies at every stoplight. I have driven over...hmmmm...500 miles with them I would estimate. The battery was disconnected while the car was in the body shop....and 500 miles have been logged since then. Still stalling.
ADAM
ADAM
The isv is a very good suggestion... Check out pcar for the diy or search the forums here. There has been lots of discussion about it.
I don't know if it matters, but you should probably try grounding the o2 sensors (the body) to see if that makes a difference.
(disclaimer, I have actually never had problem with an isv in the 993.
Just read many posts.)
Pete
Pete
