CHT Sensor Failure Q/Cold Start Issue
Anyone know if a cylinder head temp sensor fails, if it shows up as a code on the Hammer????
Got a cold start issue...car runs very poorly in cold start mode and then after warm is fine...
Any thoughts welcome.
The resistance on the cylinder head temperature sensor can be checked with a voltmeter/multi-tester. Check the value when warm and cold, it should be different. The connection is in the upper-left backside of engine bay, behind the heater blower.
