993 Forum 1995-1998
Successfully Completed!
Old Apr 23, 2006 | 03:23 AM
Bladz's Avatar
Bladz
Default Successfully Completed!
Thank you to everyone and especially Viper Bob! I had a collapsed lifter and thought it was on the passenger side exaust so I changed all three of those and I was wrong so I completed the intake side...all three and wouldnt you know it was the last one I pulled and I could tell for sure it was collapsed! What a fun job with the power steering pump taking up so much space!
Thanks again to everyone that said I should do the job myself and thanks to ViperBob...I think he needs a 1-900 number so I can pay by the minute.
In the morning I will be bleeding brakes, flushing the power steering and doing an oil change...since it is raining!
Old Apr 23, 2006 | 04:16 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
great work!!
Old Apr 23, 2006 | 04:18 AM
c993k's Avatar
c993k
Good job Paul, how long did it take to get to the lifters?
Old Apr 23, 2006 | 08:46 AM
viperbob's Avatar
viperbob
Former Vendor
Awesome Paul.... Glad you found it.
Old Apr 23, 2006 | 03:29 PM
Monty's Avatar
Monty
Bit busy then !!
Old Apr 23, 2006 | 03:32 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
The most difficult aspect of lifter replacements is actually locating which one, or at least which three. Last year, I SWORE I had one collapsed exhaust lifter, turns out, it was an intake. At least I got the correct side of the engine
Old Apr 23, 2006 | 04:08 PM
epj993's Avatar
epj993
As an fyi, what's the symtom(s) of a bad lifter?
Old Apr 23, 2006 | 04:24 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Nasty clicking sound, a clicky sound that stands out from the rest and varies with RPM. Typically most prevalent at idle.
Old Apr 23, 2006 | 10:45 PM
Bladz's Avatar
Bladz
The intake was eaiser to do since I was nervous about the exaust studs breaking. I cheated on the intake since I was going to remove the power steering pump completely but instead I opened the pump up and that was hair raising with all the little metal fan blades that fell out. The top took approx 4 hrs. The lifter was completely collapsed! When I put it all back together and turned the key started without the tapping sound...I was smiling ear to ear! Wish I would have changed the plugs and wire while I was in there. Thanks again for the help.
