Moving seat rail back to rear holes.
I am hoping to gain some additional headroom and legroom by moving the drivers seat/seat rail back to the rear holes. Do i need any additional parts (bolts, washers, etc) to perform this task, or can I just use all of the existing parts? If anyone who has done the swap could provide some insight, I would appreciate it.
Thanks.
-Steve
Thanks.
-Steve
It is a simple job Steve. No other parts needed. With that said though, make sure you have a good 6mm allen. The heads strip VERY easy. I generally use a Snap On 6mm allen socket. The front ones have a bit of a clearance issue. Just make sure you raise the seat all the way. Did I mention be careful as the bolts strip??? Good luck..
I did this recently on my 993 and it was easy to do. What surprised me is that even with the seat moved back there is still less room than my old 964 on the passenger side . That was a surprise as I didn't think Porsche had made the 993 smaller! Perhaps the foot well is much closer for some reason. Anybody know?
