Bishoff vs Gilette -- still confused...
After following the many posts on exhausts, I am still confused about what the difference between them is and which pieces are exchangable across the systems. I have a Bishoff muffler but my stock tips say Gilette, so clearly at that stage parts are the same. Reading through old posts, it appears that at some points connections are different. But where?
So, going back toward the engine starting at the tips, which parts are the same and which are different -- muffler, cat, heat exchanger, etc?
Mufflers are the same (generally), the difference is the connection type. Bishoff style has the ends flared to accept either the seal ring (also called a Buick Ball end), the gillet has the ball built into the piece and no sealing ring is needed. As far as the heat exchanger side, the bishoff is an oval opening with a non equal triangulated mounting, gillet has a round port with equal triangulated mounting holes.
Thanks. That's clear.
What still confuses me though is that when people advertise their after-mkt mufflers (supercups etc) they generally don't mention Bishoff vs Gilette. Does that mean that the same after-mkt muffler will fit either?
I own supercuppers and it didn't matter.
Rob
Rob
Any clearer?
If it doesn't matter, it would mean that the connection to the cats is the same for both Bishoff and Gillet. Is this right?
For the Supercup, it doesn't matter on the "tips" end because the tip is integrated and straight. But you'll need to figure out whether you need the donut gaskets or buick *****, if your muffler and tips are separate pieces. If you have Gillets, that would mean you do NOT have the buick ***** in your car because they are integrated. If you have Bishoff, then you probably already have those gaskets connecting between the mufflers and the tips.
BTW, those Buick ***** are not cheap. I ordered a pair and they were almost $80 with the PCA 10% off.
Originally Posted by 993inNC
Pelican has the sealing rings (buick *****) for like $30 a piece, where did you get yours?
Besides lids I also have the market cornered on mufflers,
Here is a pair of Bischofs next to a pair of Gilettes, you can see that the inlet sides are the same, the difference is on the outlets
and a close up of the connectors w/ a Bischoff donut which is also used on the Gilette inlet side
![](http://forums.rennlist.com/upload/04_14_2006__006small.jpg)
![](http://forums.rennlist.com/upload/04_14_993_small.jpg)
Originally Posted by ceboyd
so what years was what?
the Gilletes are from a '96 and '97 it's interesting to compare the finish on the 2 sets of Gillets that I have, the late set looks the same as the '95 Bischof. The early set(not pictured because they are on the car in preparation for the noise ***** at LRP) has a polished ss case
It will also be interesting to hear the noise differences, the Bischofs are by far the lightest(and nosiest at ~98dBA), the late Gilette(RSR modified) is in the middle and the early Gillete(stock) is the heaviest and quietest @~87dBA.
so the gillet mufflers are heavier and quieter?
one pair of Gilletes is stock, the other was modified by Robin(RSR)
The Bischofs, may have been more radicaly altered, all of the external braketry has certainly been removed, I have no certain knowledge of what may have been done internally, but they are certainly louder than the RSR modified Gillets. They are also very light
