993 Forum 1995-1998
Starting problem need some ideas
Old Apr 2, 2006 | 09:59 AM
Howdy993's Avatar
Howdy993
Could this possibly be an ignition switch problem?
Signed - Clueless
Old Apr 2, 2006 | 01:10 PM
Lorenfb's Avatar
Lorenfb
"During cranking
Starter voltage - Starts off at 12.82 and then drops to 6.8 while it is cranking
Solenoid voltage - 3.5-4.5 (Voltage dropped)"
That's the problem! You have something wrong with the wiring.
Old Apr 2, 2006 | 01:35 PM
Robin 993DX's Avatar
Robin 993DX
Lifetime Member
Loren,
Can you be more specific?
Which part of the wiring?
Old Apr 2, 2006 | 02:41 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Are you guys thinking its a voltage drop across the solenoid trigger wire? If so, rig up a momentary switch from the battery to the starter solenoid, directly. This may isolate some trouble.
Robin, in your case, the trick is to get the car to fail so you can troubleshoot. Really frustrating these problems are.
Old Apr 3, 2006 | 12:12 PM
Robin 993DX
Lifetime Member
Chris,
Thanks for the idea. That's something I thought about too... But I am trying to play out the scenario in my head... So when if... I get the car not to start, hook up a wire to the startet solenoid connection on the starter and run another wire from the battery and then while at the same time I turn the ignition key make the jump connection? If the car starts disconnect the temporary connection right away?
Old Apr 3, 2006 | 05:13 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Robin, actually simpler than that. Once you can get the car to -fail-, run a temporary wire from the solenoid trigger wire, to the battery. Just touch it to the battery positive side to see if the engine turns over. No need for the key to be in the ignition.
Hope this helps...
In the end, I seem to think your starter is suspect. I wish I had one laying around for you to try, since you are only a few minutes from me...
Old Apr 3, 2006 | 07:11 PM
Robin 993DX
Lifetime Member
Chris,
Thank you very much for your kind offer and input. I might just have to get another starter to give it a try, another possibility is the ignition switch.
Old Apr 3, 2006 | 07:54 PM
cabrio993's Avatar
cabrio993
Robin,
Have you changed / cleaned your battery connectors? I was having a very similar problem a couple of weeks ago. I thought it was the battery so I went ahead and bought a new one.
If the car was cold, it would crank fine, once it was warmed up, it would take 2 tries to get it to start and it felt like my battery was weak, almost like there wasn't enough juice to turn the engine over.
I found out that the lead ends that connect to the battery posts had develop a waxy substance inside. I cleaned both connectors with mild acid and cleaned them with a wire brush until they were nice and shiny. So far so good....
Why would make a difference if the car was warm or cold, who knows, maybe the resistance is greater as the temperature raises???
Old Apr 3, 2006 | 08:00 PM
Robin 993DX
Lifetime Member
Well... I haven't tried that. But it is worth a try at this point. Sometimes it is "right in front of your nose" literately.... LOL!
Old Apr 3, 2006 | 09:32 PM
zffnhsn's Avatar
zffnhsn
Robin: I think you have a bad battery. Chances are the new one you purchased is defective. Is it a gel battery? If not take the battery back to the seller. Ask them to perform a load test. I'll bet it's junk. Get a new gel battery and your troubles are over.
pph
Old Apr 3, 2006 | 09:40 PM
Jack of Hearts's Avatar
Jack of Hearts
Robin: no Porsche-specific expertise on this but on my wife's Saab, a similar problem that was driving us crazy was not fixed by a new battery or a new starter cable. But when the Saab tech replaced the ignition switch (I was skeptical!) it totally cured the problem. (And the old switch still looked perfect). Has anyone on this board experienced ignition switch failure on the 993?
--chris
Old Apr 3, 2006 | 09:49 PM
Robin 993DX
Lifetime Member
Ok, any advise on how to take the ignition switch out? The switch is secure on with what looks like two anti tamper bolts... Are those the same as the DME bolts, needing a drill to take it out?
Old Apr 4, 2006 | 12:46 PM
zffnhsn's Avatar
zffnhsn
Robin: You're wasting time and money dinking around with the ignition switch. It's the battery man!! You have a dead or weak cell. It can't provide enough cold cranking amps (click, click, click, click). It starts when warm because the alternators been providing a surplus charge. Just drive over to the battery shop and tell the guy to give it a load test. It will cost you nothing.
Old Apr 4, 2006 | 02:30 PM
ZombiePorsche44's Avatar
ZombiePorsche44
The chances of getting a starter from a junk yard that was bad/tired is very high......I actually replaced a starter in my last 911 with a brand new factory one and it was bad right out of the box.
It sucked to have to do the labor all over again but when I installed the second new one it worked perfect from then on.
I think you need an Optima gel battery and another starter........ZP44
Old Apr 4, 2006 | 07:14 PM
Jack of Hearts
Robin: I didn't know you have to drill out the switch. don't do that yet. Battery is the easiest thing to try and is the problem in 90 percent of these cases (although since you've switched it once.....) Can you temporarily swap in the battery from your 996, just to see if that is the problem?
--chris
