Manufacture Part # for 95 C4 ABS Unit
Technical Guru
The ABS/ABD (options M224 & M339) hydraulic unit part number is #993-355-955-50. However, you may also need to replace the ABS control unit depending on the production date of your 993. The Porsche part numbers have stayed the same but the units were revised so if the serial number ranges don't match you'll lose ABS functionality. If you are replacing the hydraulic pump on a MY94 or MY95 check the ABS control unit serial number for a 4-digit production date (in bold below)
ABS-Control Unit (993-618-125-00)
DI015193XXXX
ABS/ABD-Control Unit (993-618-126-00)
DK094593XXXX
If you have a 3-digit production date (in bold below) you have the old style control unit and will need to also replace that.
ABS-Control Unit
DI013720XXXX
DK093710XXXX
if you are replacing with a newer style hydraulic unit. The newer style units have a serial number greater than (in bold below)
ABS Hydraulic Unit (993-355-955-00)
462/502372
ABS/ABD-Hydraulic Unit (993-355-955-50)
463/505058
DI015193XXXX
DK094593XXXX
ABS-Control Unit
DI013720XXXX
DK093710XXXX
462/502372
463/505058
Last edited by JasonAndreas; 03-28-2006 at 04:02 AM. Reason: the new version control units can be used with the older version 993 hydraulic unit
Interesting. 95 C4 993 is interested in my ABS Hydraulic Unit. It's numbers are:
(Porsche) 964 355 755 00
The number is identical to the one you list above except for the 964 number. Is this unit really for a 964 or a 993? The 964 did not have ABD and Porsche has been known to carry parts forward so I think it's for a 993. For example, my car came with a 944 DME relay.
TIA,
Joe
1995 Porsche 993
1988 BMW 325is
TIA,
Joe
1995 Porsche 993
1988 BMW 325is
Technical Guru
