DIY (with pix!) -- Brake Fluid Flush Fandango
#48
I know this thread started awhile ago but I'll add a couple of tips.
1) I use the Motive Power Bleeder and agree just filling the MC Res. and using the Motive for air pressure only is the way to go if you can, but with the clutch portion inside the main res. it's very easy to get air in the clutch that way. Make sure you bleed the clutch when you have the MC res. FULL or you will get air in the clutch system. I put fluid in the Motive if I'm bleeding a clutch or doing a full system flush but I first flush the Motive w/ fresh (cheaper) fluid to clean out the Motive.
2) It's much easier (for me) to reach the clutch bleed nipple if I slide under the car from the opposite side and just reach up and over to the clutch slave. Of course it helps to have long skinny arms! Also, get a set of the small open-end/box-end metric ignition wrenches, Sears has great sets of these and they come in handy for many tasks.
Sears wrenches
Sears wrenches
#50
"No diff" per se -- just different pix of the _same_ operation.
i.e. copious amounts of fluid going FROM the amply-supplied motiv-powerbleeder to the resevoir and out thru' the nipple(s).
I took these pix as the _operation_ was occurring back at the rear wheel -- which is outa sight and which I'm not 'at' or 'actively monitoring'. (Can't be in two places at once!)
The inference being that I could let the bleed/flush-process 'go' at its own pace - and - so long as I had put an adequate amount of fluid in the PB - I could let it proceed without me having to run around or constantly monitor anything.
I think this is one of the 'other' benefits of the MotivPB system - not only is it a one-man operation - but you can 'let it go' and let it do it's "thang". It's (almost) a hands-off operation once you have the nipple open. Fluid is just going from one place to another - and so long as you have an ample supply of fluid at 'one end' -- it'll keep on coming out 'the other end'.
Gerry
Gerry
#51
Originally Posted by InTheAir
Does the Motive PB come with the tool for opening the nipple on the caliper?
#52
Does it have to be a flare wrench? I am about to order the power bleeder and i haven't bled brakes myself in years, but I seem to recall just using a regular combination wrench on other cars, back in the day. Do I need to order a flare wrench as well?
#53
#58
"g" Thanks for the pics; great thread. With the quality (or lack there of) of your old brake fluid will you continue an every other year flush? Kinda scary loking fluid.
Jack
Jack
#60
Personally, I use the flare to break loose the bleed screws and to tighten them when I'm done. If I have to open/close in between I use the small box end ignition wrenches. This is mainly because usually there's not a lot of room to turn the flare wrenches.
Like Greg, I've got several styles of wrenches and seem to use most of them.
