Today's Fabrication Project: Battery Hold Down
I picked up a lightweight Odyssey battery. Needs a hold down. Rennline has a very nice one, but for $135, I thought I'd take advantage of a little spare time and make one on my own. For reference, here's the Rennline unit:
I made a template for the base, cut out some 3/16" aluminum, did the grinding/sanding dance, here are the parts ready for assembly (this is kind of like watching a cooking show where all the ingredients are prepped -- getting to this part probably took about 4-5 hours):
And the assembled mount. The 5/16" threaded rod connectors are held to the base by countersunk machine screws. This and the rod are secured with some locktite:
![](http://www.plumley.org/porsche/photos/battery_clamp_assy.jpg)
Here's the base of the mount in the trunk. I used the existing hole and mounting ledge, and also ran the base under the ABS mounting bracket for additional security. It's really held in tight. In the back you can see some automotive foam/weatherstripping to keep the battery from banging into the trunk wall:
![](http://www.plumley.org/porsche/photos/battery_clamp_base.jpg)
And the completed unit in place:
![](http://www.plumley.org/porsche/photos/battery_clamp_final.jpg)
I ran the top clamp over the right edge in case I decide to mount a battery cut-off switch later - like the Rennline unit. But as I read the POC GCR, the switch needs to be behind the struts, so I may end up cutting it down. Although I provided extra clearance around the terminals, I think I need to make it even bigger around the + terminal, and may consider coating the entire surface in some sort of non-conducting material. But it was the sort of quick fun project I needed to re-develop a sense of accomplishment.
Cost? Scrap Aluminum, $8. Hardware, $7.09. Time - well, let's just say I did it for the fun of it. Weight savings - about 10 pounds from an Optima. Now, back to the suspension work...gotta get the bushings around the TRG front sway bar. And the dollar savings are needed as I just ordered a full set of ERP suspension arms from Viper Bob for the rear (ouch!).
Any comments or suggestions on how to improve or make safer is appreciated.
![](http://rennline.com/uploads/1122925727.jpg)
![](http://www.plumley.org/porsche/photos/battery_clamp_parts.jpg)
Thanks Ron. No milling machine, I'm a total hack. Just a jigsaw and a drill press - but the drill press broke so I did it all with a hand drill and a die grinder.
Not playing much golf at all anymore...and not missing it either. Race cars more fun!
Thanks again,
Don
Thanks again,
Don
Seared
Excellent work. Consider having the pieces powder coated clear once you've established the final shape.
Don Plumley Fabrications, Inc.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Andreas
Andreas
I improved the mount by 1) using a small piece of angle bracket on the bottom mount to absolutely prevent the battery from sliding L/R (thanks to V-Bob); 2) increased the size of the terminal reliefs; and 3) glued a piece of vinyl hose along the perimeter of the mount to provide insulation and additional grip. Here it is:
![](http://www.plumley.org/porsche/photos/battery_clamp_final_2.jpg)
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
I bet it would be some real eye candy if you drilled more lightening holes in it and cut off the extra material at the end to the left of the instal picture!
Cheers! looks good!
Cheers! looks good!
Seared
Andreas
Originally Posted by AOW162435
On second thought, maybe just use metal polish to clean the pieces up a bit. I found that clear powdercoating can dull the look of polished aluminum.
Thanks though!
Boost Junkie
Nice work Don - a couple of questions:
any chance of you uploading templates?
I know the top piece was extended to mount the cutoff switch but I'm not sure why the bottom piece extends to the right in the pix. Was this just to duplicate the Rennline piece?
