Mobil 1 Oil Filter
Not sure if this is any help, but FWIW I installed a Mobil 1 oil filter on my 944 years ago and replaced it rather quickly because my oil pressure suffered. You know how you usually get 5 bar or more when revving your engine??? Well, I never got over 4 bar after a few days with the Mobil 1 filter. I believe it was getting clogged.
RL Technical Advisor
Originally Posted by Robert Linton
Has anyone used one and any views as compared to Mahle, Mann, K&N, etc.?
These are made by Wix and not appropriate for these engines. The filter case is not thick enough and the pressure relief/bypass valves do not work right.
Stick with the OEM German ones and you'll not risk that motor. I used to keep a whole garbage bag full of Yankee filters that had bulged-burst casings to show people.
Baldwin filters are OK.
