LED tail/turn/reverse bulbs
Boost Junkie
Has anyone here tried using some of the LED bulbs such as those at
http://superbrightleds.com/1157.htm
in the back of yer P-cars? good? bad?
Hi Mate,
I have fitted them in the back of my 993 they give a 10% increase in brightness and respond quicker to activation from the brake circuit also less power drain so I have also fitted them in the front side lights and the interior lights, the white light is much cleaner and a pure light as apposed to a yellowish colour
Regards
Pete
Regards
Pete
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Do you guys have the part numbers for all of the exterior marker-type lights?
I can't seem to find them in the manual and would like to replace my front marker, side markers, tail lights, etc. with LEDs to match my HIDs.
I am interested in buying the following:
-Orange LED Blinkers for the front corners
-Red LED Blinkers for the rear corners
-Super White Licence Plate lights for the rear bumper
-Red LED Brake Lights
-Any neccessary resistors or relays.
Can anyone tell me the part #'s that i need for my 1996 C4S?!?!
ADAM
ADAM
One more thing, you will need special LED's that are posisioned in a way that some of them point towards different directions to cover the whole lens. They have them where some of the LED's are actually positioned to shoot the light backwards. This way there's even light coverage hitting the reflector too otherwise you would only see a 2" circle of light coming out of your tailights.
The plug in replacements have resitors built in to work from 12V however with no load on the flasher they blink very fast. The fix to this is simply get a soid state flasher made for LED's.
The hard thing is to get the right LED's to cover the large area of out tailights. Chris
1995 PORSCHE 911
Low beam headlamp
H1-55W
H1ST Silverstar High Performance Lighting: the whitest and brightest Halogen
High beam headlamp
H1-55W
Parking light
7528
Front turn signal
7528
Rear turn signal
7528
Tail light
7528
Stop light
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
High mount stop light
%COM
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: the whitest and brightest Halogen
License plate
6418
Back up light
7506
Front sidemarker
3893
Rear sidemarker
3893
Dome light
6411
Instrument-general
2721
Low beam headlamp
H1-55W
High beam headlamp
H1-55W
Parking light
7528
Front turn signal
7528
Rear turn signal
7528
Tail light
7528
Stop light
7506
%COM
Fog/Driving light
H3-55W
License plate
6418
Back up light
7506
Front sidemarker
3893
Rear sidemarker
3893
Dome light
6411
Instrument-general
2721
The "white" LEDs have a noticeably blue tint to them, which looks ricer to me. Maybe I'm an old curmudgeon, but I prefer the warm glow of the stock incandescent lights.
