The race car bug has bitten...I am going to sell the 993.
Here is a list of the mods done. I added up the parst and labor. You won't believe that it comes to (I didn't). No wonder my wiufe is pissed off at me!
Parts Estimated labor Total
$21,337 $6,650 $27,987
I will put up a full fledged ad on Rennlist classifieds soon, this weekend I hope.
69,504 Miles
993 RS Porsche factory front splitters,
993 RS Porsche factory side skirts
993 RS Tail, Getty Design
993 TT air snorkel through 993RS tail’s grill
993 RS motor mounts
993 RS transmission mount
993 RS light weight fly wheels, clutch and pressure plate
993 RS shifter
New BF Goodrich tires
Ruf auxiliary Oil Cooler
Remote on/off switch for right side cooler
Factory limited slip,
Robin Sun’s RSR mufflers.
Porsche factory Large Oval tips,
PSS 9 coil over suspension, front rebuilt in 2005 to new,
993RS rear drop links
The Racers Group 25mm front bars
The Racers Group 23mm rear bars
ERP mono-*****, front and rear
ERP rear toe links
Lowered and Corner balanced,
Aligned,
3 degrees negative camber front,
2.8 degrees negative camber rear,
Bump steer (kinematic toe) correctly set up at Mirage International
Sport steering wheel with air bag (AJ USA)
Dead pedal
DAS-sport bolt in bar
5 Lb. Halon Fire extinguisher installed in Brey Krause mount,
Emergency electrical cut off switch (TRE, N. Hollywood set up)
Big Red 993TT brakes
Litronic headlights with 100 W High Beams
New windshield
Multiple sets of stock brake pads
One (1) set of Pagid Orange front pads (used)
New front rotors
Two (2) sets of 17” wheels
Maintenance records available,
Battery hold down strap installed at Black Forest, San Diego
The car is a POC legal LP/R4 car. It has track records at Streets of Willow, two (2) time Short Track Series Champion car, 2001 and 2005.
I would rate the condition of the car as excellent. It has never been hit, no body repairs have been done. The engine has never had Check Engine Light issues and was given a clean bill of health re. air flow in the SAI system by Hergesheimer Motorsports in Lake Forest, CA. The SAI valve and manifold were changed January, 2006. The only thing the car needs (besides a new owner) is an air conditioining hose...it is in the process of going on as we speak!
69,504 Miles
993 RS motor mounts
993 RS shifter
ERP rear toe links
Aligned,
Dead pedal
New windshield
New front rotors
PS Armorer
From this list, some people would argue you already have a race car!
Good luck finding your new track weapon,
Jason
Jason
Jason makes a good point......................
It would appear to be a race car already...but it really isn't. In order for the car to be competitive, it needs to go on a big diet, strip out the interior to include the door palels...they need the RS panels to accomodate the NASCAR side protection bars, part of the needed fill cage system. I really didn't want to do this to a very streetable car with air conditioning and a 6 CD player, full leather interior, etc...all the creature comforts. And finally...were I to strip the car to race car weight, it would not be a lot of fun to drive on the street...next step, a trailer and tow vehicle....no, no, no...I am not going there.
I am buying a 80 SC coupe, that is already set up for the track. 100 less HP...300 Lbs lighter, a real momentum car. It is time to go up (GT3 Cup or GT3) or go down (SC or Carrera 84 - 89). I choose down. I don't need to go 160 mph down the front straight at Willow Springs...I get my jollies in the corners. I am a G Force junky!
Martin, you old dog. What do you have up your sleeve? So here is what I am looking at. What do you think? You thinking similar?
You posted the same time Martin. An SC huh? I was thinking of am RS AMerica potentially for a racer, but a GT3R with 450 HP and 2500 lbs is kind of calling me. The GTC3s are a little slow compared to my turbo (OK , no wise remarks). This could be fun and racable in still curent series events. Hmm, if it works look for me on SpeedVision...if they show anything other than NASCAR anymore.
Thanks to one and all...
Thanks Chris...spread the word. The car will be in Mark Kinniger's from Black Forest, San Diego, tomorrow and through the weekend...maybe longer. He seems to have some possible buyers. I'll do a Rennlist tomorrow...or maybe Sunday wiuth lots of fresh pics.
