993 Forum 1995-1998
Odometer failure
Old Feb 18, 2006 | 11:53 PM
98993c2s's Avatar
98993c2s
Default Odometer failure
Odometer has failed on my S....any recommendation on what culprit might be the best to check out first?
Thanks in advance...
Old Feb 19, 2006 | 12:19 AM
eloyex's Avatar
eloyex
incredable .. !!!!!!!!!!!!!!!!!!!
mine failed yesterday ..!!
will keep an eye on this thread .....
Old Feb 19, 2006 | 12:38 AM
jnor10's Avatar
jnor10
I went through this in the past year, as well as a few others IIRC. Basically, there is a white gear inside the speedo that is prone to failure. It drives your odometer. You can search prior posts on this and it is well documented. There is a guy in Chesapeake,VA who sells a new improved version of the gear for ~$25.00. Or you can send it to Palo Alto Speedo for repair for somewhere in the neighborhood of $200.00+.
http://www.paspeedo.com/
Hope this helps,
Jeff N.
Old Feb 19, 2006 | 12:47 AM
eloyex's Avatar
eloyex
robert ....
i found this moments ago ...
http://p-car.com/diy/odometer/
seems to be the way to go ................
Old Feb 19, 2006 | 10:01 AM
eloyex's Avatar
eloyex
I AM ORDERING TODAY THE GEAR ...
LET´S SEE IF I DONT CRAP THE WHOLE UNIT !!!
I HOPE NOT !!!
Old Feb 19, 2006 | 10:58 AM
dp2boy's Avatar
dp2boy
Just follow the P-Car thread and go very slowly. You'll have it repaired in a couple of hours. Removing the tabs to open it up is the hardest part.
Old Feb 19, 2006 | 11:37 AM
Kolbjorn S's Avatar
Kolbjorn S
Very common particularly in the hot humid climate where I live. Had the gear (from Jeff at Odometer Gears LTD; highly recommended) replaced on both cars, works fine!
See also https://rennlist.com/forums/993-forum/211866-993-964-968-odometer-repair-diy.html as well as
https://rennlist.com/forums/928-forum/237453-928-odometer-what-a-piece-of-s.html
Old Feb 19, 2006 | 08:06 PM
98993c2s's Avatar
98993c2s
Thanks everyone for the posts...I'll order the gear tomorrow...
Old Feb 25, 2006 | 12:42 AM
98993c2s's Avatar
98993c2s
Got the gear today:
Old Feb 25, 2006 | 12:55 AM
zekksw's Avatar
zekksw
Registered User
Mine quit last Saturday. Off to No. Hollywood speedometer on Tuesday, repaired and back home today, $130. 818-761-5136 No affiliation ..
Old Feb 25, 2006 | 05:24 PM
98993c2s's Avatar
98993c2s
Took about a hour to remove and reinstall the speedometer and replace the gear. Most of that time (about 40 minutes) was spent carefully removing the trim ring to avoid scratches. $29 including shipping.
Old Feb 25, 2006 | 11:55 PM
BS911's Avatar
BS911
Congrats Robert. Nice to see those dials moving again isn't it? I was really worried the first time I cracked my speedo open. I just imagined springs and gears flying everywhere. (Based on a bad experience trying to "repair" a fishing reel when I was about 10 years old.) Glad to see people getting better results out of this r&r.
