Ceramic brake pads?
Originally Posted by Mark in Baltimore
Pcar,
I'm assuming your brakes were recently bled or flushed? What kind of brake fluid do you run? I use SRF for maximum margin.
When I use my Hawks, the brakes seldom fade unless I do a ton of fast laps at Sebring, and even then they're predictable and come back quickly if I back of a little. So I think everything in my brake system is functioning properly, it's the pads that make the difference.
I've heard from some people that SRF can last an entire season, while others say you have to bleed it just as often as regular fluid... I'm not spending that kind of cash on brake bleeds before every track day.
I flush my brakes once a season and have strung the bleeding out to every three events. I'll eventually work up to four or more events before I bleed, but if I'm going to a track that's tough on brakes like CMP, and it's going to be hot, I don't take a chance by not bleeding.
Never had fade issues. $70 is cheap insurance considering how high the wet boiling point is on the SRF and considering how much time you can save by not bleeding.
