~~~Group Buy NOW OPENED - Suspension~~~
#91
I will have install pics in about 2 weeks. For driving impressions, well, I'm probably 4-6 weeks before the alignment/corner balancing is complete. However, HD/M030 or PSS9 have been installed on many cars here and everyone raves about them--albeit differently.
#96
OK everyone, Last Chance... I will actually still leave it open through tomorrow as I have told some people that were traveling etc that I would as they have been out of the country or in too many airports.......
And you folks on acitve duty that I have corresponded with, whenever you return is fine.... Stay safe...
#98
Jeff - don't know if you're keeping a tally but order option 3 earlier this week. Let me add my thanks to the choirs of others who are grateful to you and VB for putting this together.
#102
Bob--emailed credit card to you last night and I'm thrilled that we can get it asap!
Marc, mhm993@comcast.net
#103
Jeff,
Could not resist any longer, and so just ordered option 3 from Bob. Thanks to you, ViperBob and all the participants for making this group buy possible and such an incredible success. Looking forward to the install pictures!
#104
Here are some of the torque numbers for the suspension. I am updating my install info, but as a number of you already have it I wanted to make it available.
Torque Settings for 993 Suspension Install
Front Axle lb-ft (Nm)
Strut to Wheel Carrier
Upper Bolt (Camber adjuster) M12x1.5 88 lb-ft (120 Nm)
Lower Bolt M14/1.5 147 lb-ft (200 Nm)
Spring Strut mount (upper shock) to Body M8 24 lb-ft (33 Nm)
This is the factory manual setting.. Be Careful here though. The mounts have soft studs that have fatigued a little with age. MANY times when torquing to spec you can snap a stud. You may want to consider doing a slightly lesser torque (especially if you have a strut brace).
Spring Strut mount to piston rod M14x1.5 59 lb-ft (80 Nm)
Stabilizer bar
To crossmember M8 17 lb-ft (23 Nm)
To drop link and drop link to wheel carrier M10 34 lb-ft (46 Nm)
Rear Axle
Spring Strut mount to piston rod M12x1.5 43 lb-ft (58 Nm)
Stabilizer bar
To drop link and drop link to shock mount M10 34 lb-ft (46 Nm)
Toe arm locknut M12 63 lb-ft (85 Nm)
Toe arm eccentric locknut (get tight as possible. M12 74 lb-ft (100 Nm)
Hard to get a torque wrench in there)
Stabilizer bar
Rear Axle
Stabilizer bar
