Clutch pedal oddity after flush.
Bob, If only I was in Fl.. That's where I got the car from.. Always appreciate your posts and inuput.
Thanks.. I will take that route. Cost of slave cylinder if I want to do myself, and cost w/ install?
Before I did my clutch job I too had similar notchy clutch pedal feeling. And on occasion my pedal would not come back up fully! Now smooth as silk. (I replaced the slave) What cruel Porsche Engineer put the slave on top of the transmission??
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Seared
Bob is right on the cost. I just ordred the slave ($83.02) and hose ($37.26) from Sunset Porsche.
I will post an update once I've replaced the beast.
Andreas
Andreas
Wonder about the "clutch depressed bleeding"... you'd relieve the pressure on the clutch once you opened the nipple. Then there'd be nothing to push the clutch back once you closed the nipple. I always defer to Robin's knowledge, so what am I missing?
