993 Door strap metal fatigue
Lifetime Member
Lifetime Member
No need to pay $600 for that fix.... If you drive up to my house in Chino hills you can have it done for free.....
The process however is lengthy as I take the driver's seat out and disconnect the DME (just in case), and then the battery prior to welding.
Robin -- What a wonderful offer -- I just might take you up on that -- but I would insist on reimbursing you for time and materials. I'll send you an email through your link on p-car.com.
I'm really grateful for such an offer -- thanks for all you do.
Mark
Mark
There was a nearly identical thread a couple weeks ago where I and I believe other(s) describe paying $100 - $200 for welding like Robin's. There are pics in that thread too. If I could weld I'd have done it myself.
Lifetime Member
Lifetime Member
Mark,
I am not sure how I would calculate the material cost....
416L Stainless steel filler rod
Argon shielding gas
220Volt for TIG welder
Tungsten electrodes
Die grinder to grind off paint
An opportunity to melt and fuse parts of your 993 --------- priceless --------
Argon shielding gas
Tungsten electrodes
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
