993 Forum 1995-1998
Body to Engine (Trans) Ground Strap Location
Old Jan 15, 2006 | 03:13 PM
cbracerx's Avatar
cbracerx
Question Body to Engine (Trans) Ground Strap Location
OK, since I took the engine out several months ago, I forget exactly where the ground strap attaches to the transmission. I could guess, but I bet someone knows exactly where.
Thanks!!!
Chris
P.S. First 993 Engine install was easy enough, once I moved the scissors lift forward about six inches.
Old Jan 15, 2006 | 04:12 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Its is located at the lower starter mounting stud, local to the bellhousing. Always a good idea to scuff it up with some sandpaper prior to install.
Old Jan 15, 2006 | 04:24 PM
cbracerx's Avatar
cbracerx
Thanks! That is what I thought I remembered
