You'll notice in the version in post 24 I lowered it.
Luis, if someone else doesn't do it by tonight, I'll drop it down for you. I'll also add some darker shadow under the rear bumper....the more I look at it, the more tweaks we could do.
Quote:
When can I get in for an alignment & ride height adjustment?
Thanks,
Luis
Here you go..Originally Posted by LUISJR993
Hey cabrio,When can I get in for an alignment & ride height adjustment?
Thanks,
Luis
Jeff did a great job with it so there wasn't much it needed. It's perfectly corner balanced now with +/- 20 lbs difference on each side. Negative camber was added on the rear as well for better cornering.
I also installed RSR mufflers so you can have a sound that goes with your current meaner look.
Be careful of going over speed bumps or you'll bottom out!
Hope you like how it handles now...
You are the Man!Originally Posted by cabrio993
Here you go..Jeff did a great job with it so there wasn't much it needed. It's perfectly corner balanced now with +/- 20 lbs difference on each side. Negative camber was added on the rear as well for better cornering.
Quote:
Glad everyone is enjoying these so much.
There are also side, front and top drawings. In case you missed them contact me and I can send you the original (black and white line drawings) that you can paint yourself. Or.....you can have Leland Pete to them for you.
Bye the way what do you guys think of the TT tail? I am not happy with it and might do a better one.
Enjoy!
You've got PM.Originally Posted by Porscheologist
Enjoy!
