Battery acid leak from a Diehard
It looks as if battery acid has been leaking from my 1 year old Diehard. When I pulled the vent tube, it had a little acid in it. After I removed the battery I could see acid on the case under the vent tube hold. It left a white residue under one side of the battery that really bothers me, although so far it looks to be all on the surface.
What would cause this? The vent tube from the battery is connected to the clear tube in the car and there doesn't seem to be an obstruction in the tube as it passes through the trunk. Something blocking it further down the line?
I started out with Optima Red Tops and didn't have this problem, but found that they didn't last long at all.
Thanks,
John
Thanks,
John
Could be overcharging ... maybe that's why the Optimas didn't work out, I've never heard anything negative about an Optima before. You should have the charging system checked over.
Flush that area really well with a water and baking soda solution, rinse it carefully and repair any rust damage, it will only get worse if you let it sit.
