993 Forum 1995-1998
aftermarket pedals
Old 01-06-2006, 12:00 AM
  #31
nile13
nile13's Avatar
Dan, why the two dead pedals?
Old 01-06-2006, 12:05 AM
  #32
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
For the 'both feet in' moments?
Old 01-06-2006, 03:18 AM
  #33
STLPCA
Addict & Guru
STLPCA's Avatar
I actually use the dead pedal to brace myself on the track so I was concerned with both function & form. The Rennline (black pedal) fits very well & provides good solid support, but doesn't match the AJUSA pedal set & is (IMO) unattractive & cheap looking. I.e., great function with bad form.
The AJUSA dead pedal matches the others & looks great, but is made to just sit on the hump offering no real support. It's great form with bad function.
The combination is great function & great form.
Old 01-06-2006, 01:03 PM
  #34
Paul902
Paul902's Avatar
Default Drilling...yuck!
Do any of these pedal sets not require drilling of any part of the car?
Old 01-06-2006, 02:01 PM
  #35
Carrera Mike
Carrera Mike's Avatar
Cool
Paul,
I drilled mine to ensure they don't work lose while driving at high speed. 3 holes each pedal at least for me. They're locked in there good!
Mike
Old 01-06-2006, 02:39 PM
  #36
Mark in Baltimore
Mark in Baltimore's Avatar
Paul,
Yeah, the Rennline's required drilling. It's not that big of a deal; just make sure you have very sharp drill bits (start out small to avoid bit walking) and try to avoid drilling too near the areas behind the pedal arms so that you have room to put the nuts.
It also helps to use a small level to make sure the pedals are as straight as possible. I used the level on my Miata and the pedals are not off-kilter; I didn't on the 993 and they're a bit askew. Good thing I don't spend too much time with my head in the footwell or it might bug me.
Old 01-06-2006, 05:04 PM
  #37
STLPCA
Addict & Guru
STLPCA's Avatar
Originally Posted by Mark in Baltimore
It also helps to use a small level to make sure the pedals are as straight as possible. ... I didn't on the 993 and they're a bit askew.
LOL. Ditto.
There are aftermarket gas pedals that require no drilling because they either clamp onto the existing pedal (e.g., Wings) or completely replace the existing pedal (e.g., AJ-USA). AFAIK, all brake & clutch pedals are bolted to the existing pedal face after removing the rubber pieces & drilling holes.
Some dead pedals can be glued or velcroed to the rubber covered hump, but that'll be a purely cosmetic surface. To provide any real support, an aftermarket dead pedal needs to be screwed down.
Old 01-06-2006, 05:26 PM
  #38
Father of 3
Father of 3's Avatar
Gland I'm not the only one.
Old 01-06-2006, 06:02 PM
  #39
Tom W
Tom W's Avatar
Mine (Rennline) are slightly askew too. I tell people it's like the off-center steering wheel - a "feature" of the car.
Old 01-06-2006, 08:49 PM
  #40
Paul902
Paul902's Avatar
Thanks for the replies, guys. WOW, you guys are brave to drill holes in the car, especially for the dead pedal. I guess if I were to get any two pedals it would be the throttle and the dead pedal and there is no way of getting around drilling for the latter. For the brake, clutch, throttle do you have a nut on the backside, or do you tap the hole? I guess for the dead peddle you must tap the hole. Is that correct?
This place IS awesome. Have a great w/e everybody!
Old 01-06-2006, 09:22 PM
  #41
trojanman
trojanman's Avatar
Nut on the backside of clutch and brake, tap for dead pedal.
  #42
Mark in Baltimore
Paul,
There are bolts on the backside of the pedals, at least on the Rennline's.
For the dead pedal, I can't recall if it came with self-tapping screws or not. I think I drilled a smaller diameter hole and then put the screw in.
Old 01-06-2006, 09:28 PM
  #43
Ash
Ash's Avatar
I just finished installing a set if Techart pedals in my car this weekend. Nuts were around the backside of the pedals. I took along a screw with a sharp tip and scratch marked the hole location. Then 'punch marked' the centers so the drill bit wouldn't wander off. It's a lot easier if you modulate the speed of the drill starting out slowly. The hardest part was getting my fat head to fit in there under the dash area.
Old 01-06-2006, 10:28 PM
  #44
CP
CP's Avatar
Originally Posted by David in LA
I have these TechArt lookalikes in my 98 cab but I prefer the Ruf lookalikes that Gert sells....seems like a good deal for the money.
David,
Here is a Tech Art set that RUF installed in the BTR. Man the car is dirty.
Enjoy.
CP
Old 01-07-2006, 12:49 PM
  #45
Paul902
Paul902's Avatar
Default Throttle extensions!
I noticed an add in the new Pano for Rennline pedals that show you can get throttle pedal adjusters. This might be the way to go for me since I haven't figured out what style is best for me. I attached a photo from the Rennline site. Check it out!
Quick Reply: aftermarket pedals
