993 Forum 1995-1998
Tranny to Engine bolt torque Value?
Old Dec 31, 2005 | 05:57 PM
Porscheologist's Avatar
Porscheologist
Default Tranny to Engine bolt torque Value?
Ok I looked and looked but can't find this one! Does anyone know the torque value for the 4 nuts that bolt the tranny back onto the engine? Actually one of them is a barrel nut that also helps to hold down the starter.
Thanks in advance!
Old Dec 31, 2005 | 06:38 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
I cannot locate it in the shop manual either. The only thing I can find is the starter mount torque spec being 30ft./lbs.
I tighten these 'hand tight' generally.
Looks as though you are making progress!
Old Dec 31, 2005 | 09:47 PM
Rick Sylvestri's Avatar
Rick Sylvestri
Alex, You might ask the guys over at Pelican.
Are you thinkng of the re-install Sunday?
Old Jan 1, 2006 | 09:29 PM
vuugti's Avatar
vuugti
I used the starter value that Walrod quoted. P-car manuals are about the worst I've used. That said, I don't know where it's at in the manual. Mishmash garbage IMHO. Right there with my Aprilia manual......and that's italian!
The manual for my BMW R1200GS is without a doubt the best. It lists ALL torque values, broken down by group. Really user friendly.
Cheers,
Andy
Old Jan 3, 2006 | 01:19 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
The torque specification I have written down for the M10 nuts is 45 Nm (33 ft-lb).
