group buy HID bulb is dim
so yesterday i decided that in addition to the one bulb that he is warrantying that i would get a second bulb (for when i, or another local rennlister, blows another one) to avoid having to wait for an east coast turn-around (i also thought it might prompt some better service if i put something in it for him ;-)). i sent another email indicating that i now wanted two bulbs and this morning i found an email in my in box:
hi, we haven't received the bulb yet, i missed the delivery guy. but ye we can send you two bulbs no problem. for the second bulb it will be $60. and also can you give me your address and the bulb type you had. thank you!
now, i think that $60 is a bit much (since he sells them on ebay for $100 for a pair), but i didn't feel like arguing over $10 from 3000 miles away so then i told him i wanted it express mailed (so that it might get here before the weekend) and he wrote back:
hi, thank you. if you want us to mail you the 4300k jsm h1 bulbs. please paypal $73 to our paypal account: thelegend321@aol.com thank you!
so, this morning i paypalled him the $ and am waiting for some word from him...
Hey Matt - As I was next to you doing the HID install at Devek back when I'm doubly interested. I don't drive as much as you do and certainly not as much at night but I'm hoping this all works out. Good luck and thanks for posting for all of us to watch.
Lifetime Member
Lifetime Member
That certainly is a different bulb that Porsche (and many others) use, a D35S. I felt lucky to find those for $80 each in pairs. Porsche price is $145. each, BMW $195. each.
Addict & Guru
Porsche's Litronics oem bulb is a Philips D2S. Aftermarket H1 HID bulbs are rebased D2S bulbs of frequently unknown origin. The quality of the bulb & the rebasing varies greatly.
If you found new Philips, GE, Osram or Sylvania D2S bulbs for $80/pair you got a very good deal.
Seared
Andreas
i was just looking at the picture of those bulbs in the auction and they don't seem to have the wiring/connector that our aftermarket kits need. when i went to remove just the bulb i was surprised that there was no way to detach the bulb from the wiring that leads out of the headlight back to the connectors and had to cut the wires. i hope i didn't make a real mess of this...
although nick never did respond to my emails, two [i presume] new bulbs did arrive today by express mail (which i paid for) this am. i was able to install the new bulb, though it is not as trivial as simply popping out one bulb and putting in another. it requires snaking the wiring from the bulb (you cannot disconnect the wires from the bulb unless you want to snip the wires) to the ballast in the trunk via the rubber grommet that bridges the inside of the fender to the inside of the trunk. after i got the wiring through the grommet the rest was pretty simple (since i could just look at what i had done with the original). one thing i did notice when i fired up the headlights was that the new one seemed a little whiter than the original. in anycase, inspite of questionable communication from the vendor he did manage to get me the bulbs in time. i also have one extra bulb (which i am sure i or someone else will probably have to put to good use at some point...). i also wonder if it isn't a bad idea to get a couple extras now if these kits require a unique bulb/wiring harness (do they?).
If the color of the bulb bothers you enough, put the second bulb you just purchased in the other side and keep the used bulb as the spare. The 2 new bulbs should be of the same color.
Mahalo for documenting the customer service from the vendor... something others should consider if purchasing this kit in the future.
Originally Posted by AOW162435
You sure that's not an octopus? Pretty involved setup for a lightbulb.
Hope your lights are back up and running for the New Year.
Andreas
Andreas
Addict & Guru
I recently purchased a pair of brand new Philips D2S 35W bulbs from a Ebay bulk reseller for about $60
Could you post a pic of what these bulbs look like? Are they standard D2S bulbs with some sort ao an adaptor attached?
Originally Posted by mborkow
...these bulbs were supposed to be good for 2500 hours. i figure i put maybe 200 hours on them and i already lost one.
