Aftermarket outside temperature gauge
I've got a '96 cab w/o the onboard computer -> w/o an outside temperature display. I'd like to have an outside temperature display inside the cockpit somewhere. Do any of you guys have aftermarket external temp. displays that you'd recommend?
thx,
Chris
thx,
Chris
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
Oregon Scientific makes a bunch of stuff. Not sure if it integrates with your OBC, though.
Edit: Saw you have no OBC, so it should be what you need.
Hey Chris...
I'll check my records for the manufacturer when I'm back in town, but the PO of my car bought and installed an auto-dimming rearview mirror that has an integrated digital thermometer and compass... I really like it a lot.
I'll post the info this weekend.
Thanks Jeff and Terry.
According to the info. on Mito's website, Porsche is one of the brands for which the factory mirrors can't be replaced w/ Mito's. Wonder why they said that and what it takes to install one of these. Has anybody installed one of these?
thx,
Chris
thx,
Chris
Maybe it takes some less-than-simple mods to get power to the mirror... I know with mine that they had to run power from somewhere up in the headliner.
FWIW, my reciept indicated $125 to install... the place appears to be a stereo shop.
thx,
Chris
thx,
Chris
Any help would be appreciated.
Rob
I've been planning to install a Gentex AutoDim mirror with HomeLink, but found the same mounting issue. You can remove the stock mirror by turning it a quarter turn counterclockwise. The windshield mount is glued there.
The adhesive on mine is quite strong, but kind of soft - I can depress it with a small screwdriver. I thinking that I *might* be able to carefully force a razor blade behind it to cut it free. Then, clean up the residual.
If that works I can install the Gentex mount. If it doesn't, I may be screwed.
The wiring for the mirror runs up to the headliner, behind the inside rubber seal for the windshield, and down the A-pillar and fed into the dash. From there you hook up the power per the instructions. The OEM Porsche auto-dim mirror installs the same way.
If I can get to it over the holidays, I'll post the DIY.
