Brake light problem
Passed On
Pull up the driver's side carpeting behind the pedals and unbolt the floorboard. You should see the brake light sensor now connected to the brake pedal. Likely that is bad and needs replacement.
I had the same problem. Check out my thread for details https://rennlist.com/forums/993-forum/224152-fixed-my-brake-light-problem-thanks-for-the-help.html. Good luck.
