Need HELP/Decision on springs
I've looked through the archives and couldn't find anything on this so I thought I'd ask.
Last year I put Gert's Bilstein HD's on my car as the vehicle already had Eibach springs and the shocks were toast. I always had a felling something wasn't quite right and recently decided to get the ROW MO30 springs to get rid of the sagging Eibachs.
I ordered the springs from Sunset Porsche and have the right part numbers. However, my installer is telling me that the springs are too short (like 2" too short). These new springs are so short that he says there is no way to dial down the shock hats to make it so there isn't play between the springs and the mounting.
Has anybody else run into this? Are there other parts to buy to make these work? I am really confused and at a loss as I thought this was a bolt in item.
Help please!!!
Help please!!!
WOW Kelly what a nice fast response. Thanks for the link. I am priniting now and will take to the installer in the AM. This particular guy is very **** as described on the website and I appreciate his cautiousness.
Thanks again Kelly and my friends at Rennlist
Yet another shop that has no idea how to install these items (or is able to look for any resource from another shop or the internet) on a 993. He may be ****, but also not experienced with these cars.
ViperBob,
I always appreciate your comments except this time.
This installer has prepared more Le mans and MANY other race cars than many others. He simply hadn't seen this setup and is used to putting in the full coil over type suspension and didn't want to waste my money which I appreciate.
See his website for the non believers
http://www.premiersportscarservice.com/
Yes, that is a great link and ran across it when I was researching suspension options back in the day.
Dan has always been a great source for accurate, informative and easy to understand posts.
I agree w/ Bob, though... the installer just hasn't a clue on these cars, but hopefully with the instructions you provide he will do a great install on your car. Let us know how it turns out as these cars are very particular with regard to suspension and alignment setup.
If done right, you will love the new suspension.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Originally Posted by slant911
ViperBob,
![order](https://rennlist.com/forums/graemlins/order.gif)
I've been investigating the possiblility of lowering with one of Gert's combos (HD's with either H&R or RoW M030 springs-haven't decided) , but can't get my head around how/why there is the gap that John brings up. Suspect that Porsche RoW M030 spring/shock combo wasn't designed that way and it's counter-intuitive to have so much "slop". Hate to spend almost $3K, then find out it's not what I had in mind- anyone that could shed some light or comment on this?
Thanks! -Jim
Thanks! -Jim
When I installed my Bilstein HD/ ROW 030s, I followed the suggestion to use a wire tie to hold the spring in place with the shock hats. Worked well for me.
Thanks, Dave. It probably does work OK as a number of folks seem to have done it. Guess my question is more directed at this being a "proper" design/fit or is it leaning a bit toward "jury-rig"? Is there any down-side to the short spring? There is no hurry to do the project, so whatever I end up doing, I want to be sure that it's right.
Craig is right on. I have had the setup for the last 5000 miles and one Autocross and I am very satisfied with the result. (although lowering to ROW "Euro-Sport" height is just a bit low for convenient servicing- IMHO)
I can't recall whether it's covered in the suspension faq, but make sure they install the springs the right side up (my old shop had them upside down
). I'm sorry that I don't recall which side is the right side but I do know it's in a post somewhere in this forum. Lots of help right? Maybe someone can chime in w/ the proper info.
I would have looked that up but I am on a very slow connection since I have just moved. Good luck!
![nono](https://rennlist.com/forums/graemlins/nono.gif)
