Valve Cover Gasket MAJOR PITA!
Come on guys, sure the easy bolts are easy, but how on God's green earth do you get any kind of leverage for those last two on the other side of the heat exchanger. I have tried EVERYTHING to get leverage including ratchets, allen wrench keys (all of which bent or stripped), allen wrench keys attached to vice grips, wrenches, pliars and other various and sundry DIY devices, cut down allen wrench ends inserted in sockets, etc. Explain to me without taking off the heat exachangers (even a bigger PITA) how you manage to get leverage enough to torque these bolts down, much the less get a torque wrench even near those last two? What am I missing? A discrete amount of C-4 or Symtex? I just don't get it.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I use (for the aft two bolts near the exchanger) a simple L-wrench, non ball with a combo wrench slid-onto the end of the L-wrench for leverage. An extension if you will.
Thanks guys! Genuinely, always a blessing to get real world feeback. I don't know about you but, man, once the heat exchanger is removed it is an absolute piece of cake. Simple. Zero aggravation.
Thanks for the picture Jason, but that has to be the upper valve cover, no? My recent challenge was with the bottom dwellers and that nasty heat exchanger mouth. However, I get how you used the L wrench. Thanks!
Hope you all had a great Thanksgiving. And thank you all for sharing as other mechanically wayward souls like me will read this down the line!
CW: One day I will tell you the whole story of the syncros. 1st and 2nd still a little notchy. Galen and I are trying to get it right next week, swapping Swepco for Mobile 1!
