993 Forum 1995-1998
AX DE tire pressures w Pirelli Corsa's
Old 11-11-2005 | 04:25 PM
Rick Sylvestri's Avatar
Rick Sylvestri
Default AX DE tire pressures w Pirelli Corsa's
Just did the search..
found some pressures all over the map.
I'm thinking around 30 front and 34 rear w/205 55 17's front and 255 45 17's on the rear, they are Pirelli corsa's with a 50 tread wear rating.
This is my first AX/DE weekend in the C4 just wanted some feed back on what you other guys run.
Thanks !
Old 11-11-2005 | 05:51 PM
993Brendan's Avatar
993Brendan
I don't know if this is helpful, but I run 35F 37R in my 225/40/18 - 265/35/18 when I autocross or hit the track, and find that to be perfect for my tastes.
Old 11-11-2005 | 06:30 PM
Anir's Avatar
Anir
Rick,
This may not be directly applicable to your situation since I ran larger size Pirelli P-Zero C's (245 front and 285 rear on 18" wheels), but I used to start with 28-30 front / 30-32 rear for the track, and bumped it up by 2 psi for autocross.
Old 11-11-2005 | 11:38 PM
Rick Sylvestri
Thanks guys,
I'll take that into account for Sat. AX and Sundays DE
These are the track tires that came with it when I bought the car
I guess it will be by trial and error
Quick Reply: AX DE tire pressures w Pirelli Corsa's
