993 Forum 1995-1998
Urgent NO Central Locking Help Pls
Old Nov 10, 2005 | 05:04 PM
964driver's Avatar
964driver
Exclamation Urgent NO Central Locking Help Pls
Hi,
My central locking has failed on my 993 although she locks she immediately unlocks again the alarm is function correctly and will set and unset as it should but the doors will not remain locked, I have also lost the red LED's on the doors and the centre console door locking button now does nothing, the alarm does not flash to show a door open but does do it I do leave a door open as it should. Car runs ok no visual problems
Urgent help required
Regards
Pete
Old Nov 10, 2005 | 05:39 PM
kkim's Avatar
kkim
Pete,
hopes this link helps.
https://rennlist.com/forums/showthre...entral+locking
Good luck.
Old Nov 11, 2005 | 11:55 AM
964driver's Avatar
964driver
Default Central Locking All fixed
Hi All,
Its fixed!!!!found to be the plug slightly off the brain under the drivers seat, while the car was in for some minor work it was obviously driven by someone who had to adjust the seat by doing so he managed to pull the already half disconnected plug out a little more which caused the failure.......phew was looking at loads of money now all ok, thanks for all the advice
_____________________________
Cheers
Pete
993 C2 Midnight Blue (94) with gears!
"Your cleverer than you look...better than looking cleverer than you are"
