964 RS Flywheel parts needed
hello,
I would like to install a Lightweight Carrera RS flywheel in a 90 964 C2. Does anyone have the following part numbers ?
RS Clutch disc
RS Flywheel
RS pressure plate
Bearing
Pressure plate tube
Pressure plate bolts
Ring gear
Ring gear bolts
Guide tube
I searched but couldn't find a thread with these. Any help would be greatly appreciated
RS Clutch disc
RS Flywheel
RS pressure plate
Bearing
Pressure plate tube
Ring gear
Ring gear bolts
Guide tube
Follow this link:
http://p-car.com/gearfaq/
It reads:
Here is a part number list courtesy of Viken for his clutch and lightweight flywheel
N/A 993
Item Part Number Description Qty
1 964.102.239.31 Flywheel 1
2 964.116.011.61 Clutch Disc / RS 1
3 964.116.028.90 Pressure Plate / RS 1
4 944.116.080.00 Release Bearing 1
5 950.116.813.30 Clutch Guide Tube 1
6 964.114.143.31 Starting Ring Gear 1
7 928.102.151.01 Bolts 9
8 N.014.715.3 Socket Screw 8 x 45 9
9 931.102.111.00 Pilot Bearing 1 For 993 Turbo clutch and pressure plate part number
993 964.116.028.53 - Turbo pressure plate
964.116.014.91 - Turbo clutch
I
It reads:
N/A 993
I
I would also replace the following:
999 201 365 00 Cross Shaft Bushing
999 201 339 00 Cross Shaft Bushing
999 113 418 40 (qty 2) Gasket for Cross Shaft
950 116 715 01 (qty 2) Fork Bushings - I replace these on 964s as many times I find they have become brittle and tend to break. Best to replace them now
Technical Guru
Pressure plates by model designation,
964-116-027-90 968 (green)
964-116-028-03 993 (no mark)
964-116-028-53 993 TT & 964 3.6TT (red) & GT3 mk2
964-116-028-91 964 3.3TT
964-116-028-90 964 (blue)
996-116-027-51 996 GT3 mk1 & 996TT
Last edited by JasonAndreas; 11-19-2005 at 08:03 PM. Reason: updated pressure plate list
964, 96410223931, 96411601491, 96411602853, 964rs, 993, 996tt, flywheel, gear, kit, lightweight, number, numbers, part, ring, rs
