sold to a rennlister.. thanks
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
SOLD... thanks for looking
full set of 4.. one of them WAS badly curbed but I'm about to pick it up from the refinish place in about an hour..
all are straight of course!
these are the true Narrow body ones - all hollow spoked.. 18x8 fronts and 18x10 rears (rear offset of 65mm of course)
$1650 WITH the porsche color crested center caps included (plus actual shipping OR I welcome pick up in chicago) NO TIRES
paying rennlisters get 1st option! ..burton, I just responded to your PM
YES.. although very rare, Porsche did indeed make narrow body hollow spokes with proper offsets!
The part numbers imprinted on the inside rear hollow spokes are as follows:
FRONT: 993 362 136 00 8" x 18" et 52mm
19.95 lbs.
REAR: 993 362 140 01 10" x 18" et 65mm
23.36 lbs.
As a reference point, the SOLID Spoked OEM ones are 25.57 lbs. per front and 29.32 lbs. for each rear. The AFTERMARKET replica's are even heavier
19.95 lbs.
23.36 lbs.
19.95 lbs.
23.36 lbs.
As a reference point, the SOLID Spoked OEM ones are 25.57 lbs. per front and 29.32 lbs. for each rear. The AFTERMARKET replica's are even heavier![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
19.95 lbs.
23.36 lbs.
Very cool.
Thanks.. this price includes the $130 I just paid (plus time and gas) to have the one redone (I just didn't have the heart to try to resell the set of 4 with one badly curbed)... Anyway, they are now suitable for wear IMHO...
Here are some photos of the one I just picked up this morning (and I'm too embarrased to even show the before photo
) --along with how I will be shipping properly packaged to avoid any possible danger of damage in transit :
NOTE that although I did reinstall the factory metal valve stem (which I removed myself before giving to the refinish wheel place) I did NOT go beyond hand tight because I dont' know the proper torque value so keep in mind it will need to be tightened before adding a tire!)
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
..and of course the other 3 photographed along with some of the small imperfections on the rims so folks can clearly see what they are getting... I'll do one response at a time per wheel so no one gets confused from one wheel to the next...
So here is another:
So here is another:
...and last one.. (yes, the WIDEBODY - or true Turbo ones with the rear 10x18s being 40mm offset seem to be available in larger numbers -- although also rare IMHO)
so anyway... here you go guys and gals:
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
My car was originally ordered with the hollow spokes....when a buddy had a spare set, I had to have them wanting to recapture the original wheels that came with the car.
Gott en himmel those 285 tires seem wide!!!
Thanks Buddy, you know who you are!
