993 Forum 1995-1998
Third brake light/backup lights out
Old Oct 11, 2005 | 11:55 AM
csertich's Avatar
csertich
Default Third brake light/backup lights out
Well, I checked the fuses and that doesn't seem to be the problem. Anyone have this combination go out on you before? Any ideas as to cause?
Thanks in advance,
chuck
Old Oct 11, 2005 | 04:16 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Still sounds like a fuse, even though you have checked. Try removing the fuse(s) for these items and clean the connections with some sandpaper or the like. I am not near my manuals at the moment, sorry I cant check the schematic.
Old Oct 11, 2005 | 08:26 PM
csertich's Avatar
csertich
Thanks Chris. I will clean the fuse contacts and see what happens.
chuck
Old Nov 29, 2008 | 03:12 PM
C4S993's Avatar
C4S993
Mine went out too, fuse is also fine. No juice to the rear wiring harness when in reverse.
Is the trans backup light switch on top of the gearbox or on the side ? Thanks
