Tiptronic delayed upshift
#32
Originally Posted by Chuck W.
I going to start a new thread because I am curious....how many who shift manually use the steering wheel verse the floor shifter? I personally don't like the steering wheel shifter. I even got rid of the standard tip steering wheel and put in a wheel without the buttons. One of my problems with the steering wheel shifter is I would occasionally hit the buttons by accident at high speed and shoots my RPM's sky high.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#33
Button User here...call me lazy...
IIRC you can "disable" the wheel buttons by disconnecting a cable in the center console somewhere....I'll have to dig a little deeper. (gotta be cheaper than changing out steering wheels!).
Clive.
Clive.
#34
I was told that all 986's and 996 tips only have steering wheel controls. You are unable to shift using the floor shifter.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
#35
Buttons and floor for me. I used to sometimes get muddled up when shifting mid corner, with the wheel at 180 degrees, shifted the wrong way a few times but it was at low speeds and RPM so no harm done (Except to the EGO)
I like the feel of the floor shift but being a right hand drive, the turn signals are on the same side, so you have to be multitasking with the left hand.
I make that sound like it is such a job...
#36
Have used the steering wheel toggle switches almost exclusively without confusion (so far). Love my Tip but don't trust the kick-down and switch to M for serious driving. Still prefer my Sportomatic though for real 'classic' driving, we will never be parted.
PJC
PJC
#37
I've switched my tip buttons around so that up is on the right and down is on the left. Just another variation on the theme :-)
