After searching all of the posts, I could not find the answer I'm looking for; can you install the correct, OEM, Motor Sound tips onto a car that has non-Motor Sound mufflers?
My car is a '96 C4S without Motor Sound; I have installed the airbox & have located a pair of used, OEM, Motor Sound tips; part numbers are correct for wide body, etc
Thanks!
part numbers for the tail pipes you need(wide body, motor sound package) are: 993 111 252 52(right), 993 111 251 52(left). They are simply tips, bolted on the exhaust pipes - so, yes, you can replace your original tips with MSP ones.
