high rpm hesitation - any ideas?
I've experience this twice now...during some spirited driving and at high rpms, as the engine pulls towards redline, but before redline, I got engine hesitation, as if it was going to cut out...something like fuel starvation. It happened the first time in 2 gear, and then tonight at 4th gear. The car drives strong otherwise. It is not like my clutch is slipping. I got 56K miles now. Any similar experiences or ideas is much appreciated. Thanks again!
Originally Posted by Father of 3
Sounds like the rev limiter.
Yes it was before redline...and I've redlined before without hitting the rev limiter...
maybe it time for a tune-up since I'm approaching 60K?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Check your distributor caps and rotors, and while you in there, have a close look at the distributor belt condition. Perhaps some cross firing due to carbon build-up inside the dizzy caps?
