993 Forum 1995-1998
Rough idle. CEL
Old Sep 2, 2005 | 11:19 PM
RustyRotors's Avatar
RustyRotors
Default Rough idle. CEL
I started the car at work yesterday and got interupted while trying to leave. Sat there idling for a few minutes chatting. While sitting there idling I noticed that the idle seemed to be rougher / lumpier than it should be. After I got away I noticed that now the CEL is lit. It's a one hour drive to get the default code read.
Idea's?
- Ron
Old Sep 2, 2005 | 11:30 PM
kkim's Avatar
kkim
Go to your nearest Autozone... I believe they will read it for free. You need to know the code to even begin to know what to look at.
Old Sep 2, 2005 | 11:48 PM
mborkow's Avatar
mborkow
where are you?
Old Sep 3, 2005 | 12:04 AM
RustyRotors
Vancouver Island. Canada.
Old Sep 3, 2005 | 10:33 AM
Bull's Avatar
Bull
Impossible to tell. My similar problem turned out to be a bad MAF sensor, but it could be many things.
Old Sep 6, 2005 | 12:46 AM
RustyRotors
Default Now the CEL light is out.
Idea's?
- Ron
Today the CEL light went out. Started normally, noticed light not on. Drove for twenty minutes light still out.
What does this indicate?
- Ron
Old Sep 6, 2005 | 01:16 AM
grmnxtc's Avatar
grmnxtc
In all seriousness, about the only thing for sure it tells you, is that the emmissions system has (or had) an error, bad enough to light the warning light.
As KKim has said, take it to an autoparts store. Most will read the codes for free.
You can then report back with the error code number and you'll have more data opun which to diagnose the problem.
Clive.
